I am trying to figure out how to adapt a rear driveshaft to a dana 60 to a NP241. (damn near the same as a 231) To say the shaft will be at an angle and short is an understatement. Doing it the expensive way is easy. Anyone know of a strong way to shorten the tailshaft and to get a double cardon shaft to bolt to the yoke from the case? I am using 1410 joints and am thinking that I may be able to machine the cases outer slip yoke, weld on a round disc, machine that true and put on a bolt pattern to match the driveshafts flange. and turn it into a flange to bolt up the driveshaft. To shorten the case I am thinking will require buying the tailshaft. Thinking of the hack and tap deal I have seen before. Any ideas? :confused:
slip yoke dilema
You could make your own hack n tap for it. But would be alot easier, stronger and time saving to just get a good SYE kit for it.
http://www.jbconversions.com/pages/p...c_std_sye.html
We comp cut mine and had everything except the fuel pump and drive shaft done in one night. It aint rocket science. order a an RCI cell and lengthen your own DS and your golden . or skip the cell and just put the fuel tank in the rear in place of the seat . Tell him to take his purse off and get cutting
what exactly are you working on? if your 241 is driver drop and bolted to a 23 spline tranny,just swap it out for a jeep 208,wich is allready fixed yoke and same low range(2.61).
also if angles are a prollem you are prolly better off staying with single joints. a double cardon joint doesnt allow for alot of angle without taking it apart and alot of clearancing
if its not street driven,just turn the rear pinion up as much as you can to lessen the angle at the t case.at road speeds you may have some vibes from the angles being different,but if its not a daily driver its prolly not that big a deal.scotty
77 scout II truggy
84 chevy "home made crewcab"
Originally posted by scotty85 View Postwhat exactly are you working on? if your 241 is driver drop and bolted to a 23 spline tranny,just swap it out for a jeep 208,wich is allready fixed yoke and same low range(2.61).
I have one of these NP208's if you want to go that route?
Originally posted by 94Dodge Truggy View PostHe likes the 241 for strength. (stronger than a 231) Is this 208 equivalent? It is a dd and offroad. He did a spring under and it is a low rider for now with 60's and front four link. Not my choice. :p
208 is very good t-case well proven for years in Chevys etc.. They came on all the military CUCV one tons also.
Originally posted by JET455 View Post208 is very good t-case well proven for years in Chevys etc.. They came on all the military CUCV one tons also.
yes,208 is a good case. i personally would run a fixed yoke 208 over a slip yoke 241 any day in a trail rig.
i will be using a 208 behind the sm465 in my truck,whenever i get around to putting that in ;)scotty
77 scout II truggy
