How do i figure out what gear is in my axle? Incase someone knows off the top of their head, its a 14 bolt full floater in a 1988 3/4 ton,2wd suburban with a 454 and Th400.
Announcement
Collapse
No announcement yet.
What ring and pinion?
Collapse
X
well if this is an option jack up the burb and rotate the tires one turn and count how many times the yoke on the pinion turns and that will get you close. if you have a grease pencil to make a spot on each it makes it easier also.One of these days Zuk 2.0
Originally posted by Nuts View PostYeah, I was hoping to avoid that and that there would be a number stamped somewhere I haven't found yet.One of these days Zuk 2.0
u can get it from the code in the bottom of the inside of the glove box
look for the one that starts with g
gt4=3.43
gt5=4.10
gu4=3.08
gu5=3.23
gu6=3.42
1 starts with h
hc4=4.56
g80 means its a limited slip or posietractoionFor you guys who can't drive, I have owned a frame rack for several years. Prices are based on your skill and ability to wreck it....
Originally posted by fabricator View Postu can get it from the code in the bottom of the inside of the glove box
gt4=3.43
gt5=4.10
gu4=3.08
gu5=3.23
gu6=3.42
1 starts with h
hc4=4.56
Just remember that the code in the glovebox was what it came with from the factory 20+ years ago. Probably a good chance the axle and gears are still original, but unless you are confident of the history of the truck there is always a chance it was swapped out at some point in it's life. The only 100% sure way is to pull the cover and check the numbers stamped on the ring gear.
