Im new with jeeps and i have a 2000 xj thats lifted.... the part that runs across the front of the frame underneath the motor is loose... it connects to rods on each side with like a pin in them that can be adjusted higher or lower. Whats this called and i cand tighten it.. My numers 859 250 9560 if u wanna call it be greatly appreciated!
trying to figure out what a parts called
yeah sounds like swaybar dissconnects which should be connected in two places on the frame and then have a rod on each end going down to the axle.
if its loose at the frame hopefully the brackets are still there and all you need to do is tighten them or maybe replace a broken bolt if missing
if you could get a pic that would be the best and dont be afraid to be pointing to the problem area in the picOne of these days Zuk 2.0
