Can I take Cj outer knuckles and do a hub conversion on my Xj and then put the bolt pattern adapter spacers on the back to make it all work?
Dana 30 hub conversion
http://www.reiderracing.com/product_...ducts_id=32424
here is a link to the knuckles I was talking about
Originally posted by jfiscus View Postwhy? I would assume running a full-time front locker?91 fj 80 on 37 Nitto Muds with a 10k winch. Cage and sliders coming soon.
Originally posted by sarge View PostIf you have a CJ 30 couldn't you use the inner C's and knuckles on the XJ 30 ??? just an idea .... prolly alot more work then it's worth but an idea.
Scotty has been wanting to do this for a while and has looked into it a lot. Maybe he will speak up
the tube diameters are the same- you can carefully cut off the xj C and persuade the cj C onto the xj housing. however,you axle is essentially narrower now,so youll need a custom inner shaft
i have had this project on the back burner for a long time now,lol... in order to use stock xj inner shafts you need to space the cj inner C out a couple inches,in whatever manner you are comfortable. anywhere from changing out the tube ( ) to sleeving it with something.
ive got cj Cs with a couple inches of tube still attached. when i determine exactly how much wider it needs to be im planning to weld the 2 tubes together,then sleeve the joint with 2 halves of tubing(welded together,and to each tube) another method that would be alittle more effort(unless you own a machine shop) would be to extend the xj housing with a bigger tube,then machine the cj inner Cs to slide over that larger diameter.
if you have any other questions let me know,or of it helps you any i can snap a few pics later. right now i gotta get movin to go help dave pick up his new junkscotty
77 scout II truggy
84 chevy "home made crewcab"
