Ill try and make this short. I bought a 350 with a TBI. I'd like to run a fuel injection, cause let's be honest, no one offroads on flat ground. The person I'm building the jeep with (stubborn father) wants to run Carburated because of the throttle response, and easy to operate. Here's my question, do I run fuel injected, or do I spend the money to convert back to caburated? I know Holley has a 4wd carb. And I know with Fuel Injected you have to worry about a wet computer. They both have pro's and con's. Any input is greatly appreciated, thanks!
caburated vs fuel injected.
Throttle response is just as good with injection. Can be harder to work on but ultimately is more reliable in my opinion. I have had my jeep on steep hills and almost over and with out injection would have stalled and would have put me in bad situations. Keep the injection. If you dont you will wish you had.91 fj 80 on 37 Nitto Muds with a 10k winch. Cage and sliders coming soon.
Originally posted by itbrokeagain View PostThrottle response is just as good with injection. Can be harder to work on but ultimately is more reliable in my opinion. I have had my jeep on steep hills and almost over and with out injection would have stalled and would have put me in bad situations. Keep the injection. If you dont you will wish you had.
Originally posted by FollowMyRuts View PostThat's what I was saying, plus we're going to be running a Comp Cam Thumper cam that's going to make it rev up quicker. Thanks for the advise!
Any thing but a very mild cam that affects idle vacuum too much will require major retuning if it could be made to work smoothly at all. I would find a cam meant to work with the TBI.89 YJ EFI AMC 360, T18a, D20, built D44, 14 bolt, 38" Creepy Crawlers.
