After a somewhat discouraging run at haspin last weekend, I've realized what I need to work on. My question is, can I take off my tcase drop without lengthening my drive shaft? I have a sye and cv shaft already. Just don't know if it would pull the slip yoke out too much. Its only a 1" drop
tj tcase drop removal
You should be fine but nobody can say for sure without looking at it in person. As you raise the transfercase backup you chouls also adjust your pinion angle accordingly which will minimize then amount your driveshaft lengthens. One of my favorite mods was putting a "tummy tuck" skid on my TJ.Ian
If you have a SYE there is no reason to have a transfer case drop. If you remove it, you will most likely have to adjust your upper control arms so that your pinion points at the transfer case. It will be pointing a little low and you will have to lengthen them.
I put the lift on years ago before I knew any better, my control arms are factory non adjustable. I don't think I have that much adjustment. The drop came in the kit. It is a superlift short arm kit. Would I need to get adjustable arms first?If you don't want it broke, don't let me drive it....
Honestly I don't know for sure. I would just take out the spacer an see how it rides. It would only take 30 mins to figure it out. If you do have vibes then you would most likely need adjustable uppers. Check forums for some used ones if you are wanting to save cash. If your lowers are adjustable they might have enough adjustment to stop the vibes.
The purpose of the t-case drops are for the driveshaft angles, not the length. The 1" drop makes a pretty small difference in the length (only a fraction of that 1") and just suspension articulation causes more length differences.
Just as said above, remove it and go for a drive. With the SYE and CV there should be no reasons for it in regards to the angles.
Originally posted by tjrider View PostI'm not worried about the angle as much as drive shaft length. The D shaft was made with the lift and T case drop installed. I guess well just try it and see
So I'm balls deep in taking these *****es off.... Its pretty hard with no fire wrench. I had to cut the side off the spacer, then cut the bolt in 1/2, then wrench them out with vise grips. Holy hell!!!!! I got one side out, so I'm pretty well committed. Don't think DS angle will be an issue. It sucks with an angle grinder and beer for fuel. Sacrifices.....If you don't want it broke, don't let me drive it....
Glad to see your making progress.Half way there...Your welcome to bring it over tomorrow after I return from the wife's doc visit.I just purchased a new can of Never Seize.
NickJust a 200 dollar cherokee that wouldn't start ..
