yeah cheap and simple to build. upgrade 4 link instead of taking two steps back
tj rear leaf conversion
I will say that aside from having crappy leaf packs to start with, I've had no issues from the rear(I do run a traction bar though)... whereas up front I've had to do the following:
-Replace every single one of my joints at least once(I went with Ballistic joints first time around. Never again, they build bull**** and they have poor company ethics and you'll be lucky to ever get your stuff)... now running Ruffstuff 1.25" heims without issue.
-My bumpstops that I used actually had one stretch over the factory bump mount which kinda sucks. Not a big deal though, $60 IIRC at Jegs.
-I have LH/RH threads on my lower links and upper link... I've caught them trying to come loose a couple times. Check things regularly... if not then drive in the snow and make sure they get rusted in place... not coming loose now
The primary reason I did leafs the first time is that they're simple(backed up by the fact that I had the rear mocked up and done within a week or so... vs several weeks for the linked front), I didn't have to cut the frame at the hump(I was pretty nervous about doing this with a 110v welder), and frankly I really like the look of the shackles out back.
FWIW Brad Kilby has a leaf sprung rear TJ and it evidently works pretty well.
http://www.jeepaholics.com/feature/0009/0009.htm
If you want some inspiration, look up on Pirate for stuff involving "Covered Wagon 4x4" or something to that effect... it's nothing but a group of badass leaf sprung vehicles.
Well set up leaves will work way better than poorly set up links. That said you'll probably spend close to as much $$ finding out what makes your leaves work well as you would in up front costs for all the joints/tubing/threaded inserts/coil springs and in the end you need to buy good shocks no matter which setup you go with.
One thing that bugs me about my leaves is that one of the front spring hangers is about 1/4" further forward than the other, so sitting on flat ground the right side is lower than the left. It also affects spring rate because of the (very) slight difference in shackle angle. It's a relatively easy fix, but I'm going to fix it by just cutting the whole Jeep up again... this time new motor and everything
edit: If you want to come check out my Jeep in person/go for a ride just send me a PM.
Originally posted by flatlander757 View PostI did it with Old Man Emu XJ leaves.
http://www.pirate4x4.com/forum/showthread.php?t=768019
If you decide to do it, but good leaves from the start. It rides so much better with these leaves it's silly. Flexes plenty well too.
That said, if you can swing it then go 4-link with coils and shocks w/ an anti-roll bar.
My Jeep will be getting torn down some time in the near future to cut the tub in half and redo everything basically. Downsizing to 37s or 38s, Toyota Landcruiser axles, trying to drop it down to around 3000lbs, etc etc. I'm going to be 4 linking the rear, probably another 3-link up front this time too though but with coilovers hopefully at all 4 corners but we'll see....
Point being if you plan on doing this, I may have my entire setup for you to buy off of me, bumper, leaves and all.
This is the closest to a sidehill pic I've got:
Roughly 12" of stretch, here's a pic to get an idea of the overhang in the rear. With the new leaves it's a bit of a better angle though(replaced because my bastards packs blew ass).
sigpicchris hodges
Originally posted by flatlander757 View PostI will say that aside from having crappy leaf packs to start with, I've had no issues from the rear(I do run a traction bar though)... whereas up front I've had to do the following:
edit: If you want to come check out my Jeep in person/go for a ride just send me a PM.If you don't want it broke, don't let me drive it....
Originally posted by gothodgie View Postfj60 in the front and fj80 FF in the rear ?
Originally posted by tjrider View PostIf the leafs work so well, why are you switching it back to 4 link? The whole thing just seems simple and easy to me with the results I'm after. The rear doesn't flex much now with the sway bar on it. It looked cheaper to leaf it than buy all the rod ends and brackets and such..... but I've never designed anything before either
FWIW I have zero axle wrap which can be attributed to the traction bar.
Originally posted by tjrider View PostSo are you for or against? You've said both s:confused:ides.....
http://www.pirate4x4.com/forum/showthread.php?t=1005604
Unlike regular leaves, if the body goes past the tipping point, revolver shackles will just let go and the body gains momentum and flops over sideways... normal leaves will gradually go from "compression" to "stretch" which helps with stability.
edit: yellowjacket beat me to it.
Originally posted by tjrider View PostSo I found out that RC offers a long arm upgrade with arms only for $900. Not a bad price to me, and it will remain a four link. Thoughts?........
Originally posted by tjrider View PostI know, but I don't want to cut the brackets off for a triangulated 4 link. Its standard 4 link. Has to be better than a SA kit.......
The joints on the RC stuff is known to wear out fast and you are going to put it on a daily driver. The kit is bolt on and uses bad geometry on the rear links to make it easy to install. Lots of people have troubles with suspension unloading and bad handling characteristics.
Why do you want a long arm? better flex? Cause you can get more than usable flex out of the factory short arm set up on a TJ. Here is mine with Currie arms and 12" travel shocks. If I went to long arms, I would just get hung up more on rocks and hate it.
I am not sure if this is fully flexed out but its the only picture I have right now.
