Originally posted by 94Dodge Truggy
View Post
Necessary to cut off runflats?
1994 YJ, 4.0, 5 speed.
The 12 bolts (I have read) were for the increased tire pressure that goes with radial tires. The 8 bolts were for older/smaller bias ply and then when they wanted to go to radials the stronger design was created.
This is of course here-say (sp?), as I really have no idea.
I have 12's with the rubber ring (NOT the rubber run flat... there was that option too, I have transported one for a buddy... I wouldn't want to try to jamb one of those bad boys into any tire) and I haven't had any issues, but at the pressures that we run, I can't see any downside to the 8's once you've cut the magnesium (alloy?) runflat off...
And yes, the bits that you cut off and the dust that you make, all make the campfire a little more exciting... TRUST ME. (you can easily turn the dead of night into daylight)brad
sigpic
Originally posted by KargoMaster View PostThe 12 bolts (I have read) were for the increased tire pressure that goes with radial tires. The 8 bolts were for older/smaller bias ply and then when they wanted to go to radials the stronger design was created.
And yes, the bits that you cut off and the dust that you make, all make the campfire a little more exciting... TRUST ME. (you can easily turn the dead of night into daylight)1994 YJ, 4.0, 5 speed.
Originally posted by jfiscus View PostThis guy just cut his runflats, maybe you can get ideas here:
http://www.mv4w.com/modules.php?name...iewtopic&t=202
Originally posted by crazi429 View PostThese are my wheels I tried the sawzal route and found it to be a real pain. I came up with the whole saw trick and everything was much quicker and easier. I was doing it all by my self and it was a real pain to hold the run flats while cutting them. I did all my cutting outside the shop to reduce risk of fire in the future from all the shaving.
Thanks for all the help. Worked out great1994 YJ, 4.0, 5 speed.
Weights for your information:
35 lbs - H1 rim only(no beadlock or runflat)
47 lbs - H1 rim with complete runflat
41 lbs - H1 rim with beadlock (runflat cut off)
12 lbs - Runflat
6 lbs - Beadlock only (runflat portion cut off)
These are in no way exact numbers but close. I put them on a household scale that a person would weigh themselves on.1994 YJ, 4.0, 5 speed.
Originally posted by 94Dodge Truggy View PostYeah my 42" swamper tsl's and h1 rims were 148lbs!
The new setup will be almost 200lbs!
Someday I would'nt mind upgrading to aluminum rims with stauns, but this is a cheap option for now.1994 YJ, 4.0, 5 speed.
Originally posted by JeepHD View PostSomeday I would'nt mind upgrading to aluminum rims with stauns, but this is a cheap option for now.91 fj 80 on 37 Nitto Muds with a 10k winch. Cage and sliders coming soon.
