New-to-me tow rig is an 02 Suburban 2500 with the big 8.1.
I've developed an incredible itch to crank up the torsion bars and stuff a set of 35s under it. Combination tow rig and light-offroad puppy-bus.
I know the IFS isn't exactly the hot ticket on the trails, but I assume the 2500 stuff is stronger than the half-ton, and this would only be rutted-dirt-road type of wheeling.
The worry is, this IS the tow rig. If/when it breaks, it has to be fixed to get it home.
So, what breaks, and how field-repairable is it? I assumed it was mostly CV half-shafts. Carry spares, swap em out, not so bad. Or, since they flange-mount to the diff, can't you just unbolt em and drive on in 2wd?
Doing a little research, I guess the streering linkage is fragile too. I can change out the steering on my XJ in about 15 minutes flat. Is the Burban stuff as easy?
Anything else? Any experiences?
Thanks all!
Thanks all!
hate on...
