I have been trying to figure out what sye kit I have so I can try to make my speedometer work. I bought the 231 with it already on there and previous owner bought it that way too. It looks like the rugged ridge mega short but my sender only has 2 wires. Their sye kit has 3 wires according to the manual. The grand Cherokee had a gear driven sender. Will this even work??? I found a write up about a calibration box but don't know if that is what I will need or not. Thanks
????What sye kit do I have??????
There are different kits to accommodate either the electronic or mechanical speedo. The 231 in the picture is setup for the electronic and you say your Jeep is setup for a mechanical speedo. As said above with the correct kit the original speed sensor or speedo housing will just bolt in to the new SYE housing, but obviously you can't do that. Not really sure what you would need to do to convert, but one option is just to buy a cheapo GPS and mount it on the dash!
Originally posted by tjrider View PostI have the JB conversion super short sye. It converts the speedo gear to an electronic sensor. Comes with the kit. Its a very common set up. Check them out
Originally posted by jlynch View PostWhy the F**k are you worried about a speedometer on a off-road rig?
I'll check out jb conversions thanks. Hopefully they can make what I have work. If not I'm sure I'll need the computer flashed for something by the end of all this and they can delete it?????
Thanks everyone
Here's the best I can find.
http://www.seriousoffroadproducts.co...47ed429728b766
No idea if that will be the correct plug for you.
