It seems the majority of my oil leak is from my passenger valve cover gasket. Is there anything special I need to know about replacing it and dealing with the wiring harness?
7.3l valve cover gasket
I just put GP's in my 2000, cost me $80 using Motorcraft factory parts. Don't use anything but OEM glow plugs , the internets full of horror stories about faulty cheapo GP's that deform and break off in the head.
I also just did new valve cover gaskets and harnesses .
Originally posted by itbrokeagain View PostIs this as easy as changing sparkplugs? This morning it was very difficult to start and it blew tons of white smoke for a minute. I was told the smoke was normal for a 7.3
Yea. I had my drivers side tore apart, all plugs replaced and put back together in a hour and a half. Now the other side took 7.5 hrs due to circumstances i dealt with on that side. But yes their pretty simple. Basic tools, twelve pack and a radio you should be good. Oh and make sure you dont start the truck up near a wall, roll it outside you will have a little oil come out the exhaust which is ok
Its just leak down from changing glow plugs
