So what's the plan? Who all is going on Sunday? 50% chance of rain, too.
Haspin Shake down
It has a clutch and electric fan. When it started overheating I replaced the water pump and thermo but, still randomly overheats. Jfiscus said maybe air pocket in head to remove temp sensor to bleed air out. Not tried yet. Might pull radiator to inspect.
Jeep 4.090' Jeep XJ Buggy - 5.5 custom lift, 33" TSL's, locked
01' Softail
01' Dodge Ram Cummins 3500 4X4
71' Dodge Challenger
Shane
Scott,
I'll leave Middletown about 0800 Sunday morning. I assume you will post up early that morning if you are advised of conditions that cause you not to go. I will PM you for a cell phone number incase I have trouble finding the park.
I too, will be watching the temp gauge. But it is a shake down ride..
Johnsigpic1950 CJ3A. Oddfire 225 V6, T-86 transmission, Dana 18 transfer case, 4 wheel disc brakes, locked front and rear. Manual saginaw steering. Warn winch, 9,000#.
Chris (502EFI) and me want to go but he has church sunday..We might be there saturday morning and stay all day if it rains tonite..If anyone is going to be there saturday let me know and maby we can hook up..Last edited by fredrader; 09-07-2007, 05:40 PM.Miamisburg,Ohio. Cell# 937-361-7267
Work in progress
http://smg.photobucket.com/albums/v2...0M1008%20CUCV/
Originally posted by xj-up View PostIt has a clutch and electric fan. When it started overheating I replaced the water pump and thermo but, still randomly overheats. Jfiscus said maybe air pocket in head to remove temp sensor to bleed air out. Not tried yet. Might pull radiator to inspect.
Jeep 4.0
Pulled radiator looked ok, I found a small crack in my reservoir. My reservoir is pressurized from factory with no radiator cap. I will try to repair. New one is $40.0090' Jeep XJ Buggy - 5.5 custom lift, 33" TSL's, locked
01' Softail
Shane
Originally posted by xj-up View PostLoaded and ready to roll to Haspin tomorrow. Are you guys still going. Be that around 9:00amI want to be the reason you look down at your phone and smile........then walk into a pole.
