Old 09-24-2014, 03:13 PM   #1
monkeystrong
Señor Monkey
monkeystrong's Avatar
Cleaning out the garage..
I am cleaning up the garage and have a few things for sale.
Chevy 350 4 bolt main, running motor could use freshened up, on engine stand. complete engine from intake to exhaust Stand and engine $250.00
Turbo 400 - 2 wheel drive. this is a good one to rebuild and adapt to whatever transfer case you want. $100.00
AMC clutch and pressure plate (new) Should be good for amc applications was going to be behind an amc 360. $50.00
Stock TJ coil springs. $25.00 sold
Ford HP dana 60 front housing. This housing has all the brackets removed already and is ready for coil overs or coil, etc. This is a bare housing no gears, just housing. $300.00
I have more stuff...
I have a TJ bikini top with windshield channel. $20.00
TJ door surrounds for full doors. $10.00
Dana 30 spare axle shafts. $10.00
Jeep spare tire cover. $5.00
TJ factory side steps $15.00
TJ Factory front fender flares. $15.00
(Everything is OBO.. I really just want to clean up the garage to prepare for selling the house.)
Andy
513- 3six8-nine 104
Old 09-24-2014, 04:15 PM   #2
I'll take the coils, thanks...
Old 09-24-2014, 07:46 PM   #3
Jonesy
Jonesy's Avatar
I'm interested in the motor and tranny.
JT Jones
83 Toyota - beater
87 Toyota Truggy
Old 09-25-2014, 08:14 AM   #4
monkeystrong
Señor Monkey
Let me know when you want them
Old 09-25-2014, 08:15 AM   #5
monkeystrong
Señor Monkey
Give me a shout
Old 09-25-2014, 02:05 PM   #6
I'll get em from you at the tour. Thanks!
Old 09-26-2014, 03:10 PM   #7
kyrel69
what year is the ford dana 60 houseing
Old 09-27-2014, 12:50 AM   #8
monkeystrong
Señor Monkey
87 or 88
Old 09-27-2014, 07:42 AM   #9
kyrel69
87 or 88
thanks but I was hoping for a older one
Old 10-01-2014, 12:12 PM   #10
monkeystrong
Señor Monkey
What's the difference? Its a king pin and as far as I know fords are all the same width.
Old 10-01-2014, 12:17 PM   #11
I think. 80-up (not positive of year break) were diff width than. 78/79
Old 10-01-2014, 12:30 PM   #12
monkeystrong
Señor Monkey
The undesirable front Dana 60 axles will not be covered by this article, and include:
74-75.5 Ford low pinion drivers side closed knuckle drum brake with 30 spline inners, 19 spline outers, small ujoints and weak knuckles.
75.5-77 Ford low pinion drivers side open knuckle disc brake 30 spline inners, 19 spline outers, outer knuckle spindle pilot hole is smaller than 78+ axle and is therefore notched to allow 1480 series U-joint tp pass through.
94+ Dodge drivers side low pinion CAD unit bearing hub 32 spline 1.31” coil sprung Dana 60s
Any other closed knuckle Dana 60, like those from a Jeep M715 that had coarse spline axles
BillaVista axle Widths:
Ford 78-79 F250/F350 kingpin drivers reverse leaf 69.25" internal 35 / 30 31.5" dual piston 5
85-91.5 F350 kingpin drivers reverse leaf 69.25" internal 35 / 30 36.5" dual piston 5 about 3.5" more to drivers side than 78-79
92-99 F350 balljoint drivers reverse leaf 69.25" internal 35 / 30 36.5" dual piston 5 about 3.5" more to drivers side than 78-79
This axle is listed on BillaVista.com as one of the desirable axles.
Old 10-01-2014, 12:37 PM   #13
Basically it all boils down to bracket width (if the spring pads were still on it) and length of the drivers side axle tube.
Old 10-01-2014, 12:46 PM   #14
Looks like the axle shafts won't interchange between the years. Different lengths.
Old 10-01-2014, 01:43 PM   #15
kyrel69
yes all that is right. I have a 79 in my jeep now and about to build a jeep for the old lady and would like to run the same axles front and rear as mine
Old 10-07-2014, 12:34 PM   #16
monkeystrong
Señor Monkey
edited the list of things for sale.
Old 10-07-2014, 01:42 PM   #17
muddinredneck513
muddinredneck513's Avatar
You know what yr the motor is?
Old 10-07-2014, 04:09 PM   #18
monkeystrong
Señor Monkey
the motor is a 70'. it came out of a 1970 gmc along with the transmission.
Old 10-07-2014, 04:33 PM   #19
I'll take those D30 shafts, too, thanks.
