Old 05-23-2010, 05:02 PM   #1
Trigger
Looking for Opinions - V8 Swap
I've got Pater's old YJ and am looking to increase the power by swapping in a V8. Those of you that have done it, what would you recommend. I want to be fuel injected and I want a reliable motor, that has decent power. I don't need 500+ HP, but I would like it to be healthy. Some thoughts that have come to mind are 5.0L Ford, 5.3L Chevy, 6.0L Chevy truck and LS motors. Plans are for an auto tranny and an Atlas transfer case. Pros, cons, experiences? Budget is an issue, so I'm not looking to spend a ton of money, but I know that it's going to cost me some. Let me know what you guys think.
Old 05-23-2010, 08:43 PM   #2
TomH
Gearhead
TomH's Avatar
Gen-III 6.0L - Check
Auto - Check
Atlas - Check
Lots of support, lots of options, easy, great $/hp, always fires and runs, would do it again in a heartbeat.
Old 05-23-2010, 09:31 PM   #3
I'm using a 5.0L.... aftermarket support is pretty good but getting some age on the overall platform, so I would suspect that the 5.3/6.0/LS motors will be all the rage very soon... 4.6 modular??
Booo hiss on the auto tranny, but I might just be the last one driving a stick in the world... the way things are going, I have limired choices now, but I will not have any choice soon...
Atlas/STaK sounds like the most expensive part... but you get what you pay for... IMO
My last truck was 5.3 and 4L60e... I'm rough on things... Reaction sun shell went bye-bye at 116k... just for perspective. I was about 24 hours from pulling the driveline for my jeep (like Tom said... they're reliable) and parting the truck if it didn't sell, of course it sold then...
just my $.02
Old 05-23-2010, 09:32 PM   #4
There is too much support for the 5.3-6.0 motors to ignore them. I would also go with a TH350 or 400 if you don't need OD.
Personally, I would think seriously about a 4.0 based stroker. I've seen your jeep go a lot of places like it is, but a bit more oomph wouldn't hurt.
Old 05-24-2010, 07:55 AM   #5
New generation 425 hp hemi! Depending on the wheeling you do you may want to make sure it will keep oil pressure at many different angles. A 5.9 dodge motor is hearty and I know where one is cheap and complete. The less sensors and ease of troubleshooting is key for trail motors. Titan sells a 4.7 I-6 for under $2500 with a warranty. Will the 6 cyl. in your jeep ever give up?
Old 05-24-2010, 09:37 AM   #6
Keep the I-6 and stroke it. The V-8 isnt a bad thing but the 6 cyl is in it works and its wset up to be there. The V-8 swap takes some set up to get it all right. Sometimes I wish I had kept the 4.2. Never gave me any trouble.
Old 05-24-2010, 12:01 PM   #7
Trigger
It hasn't given up yet. Oil pressure is still low, but it still fires right up. The Jeep does pretty well for the motor that's in it. I just had some trouble the last time I was out and guys with bigger HP were able to power through some stuff that I got stuck on. It's a rarity that I can't do something, but when I went to really romp on it, it was lacking.
Old 05-24-2010, 12:38 PM   #8
Stick a blue bottle on it and use sparingly.
Let me know when you use it beforehand though so I can get my catchers mit out for the shrapnel.
Old 05-24-2010, 12:54 PM   #9
BIGRAM
Ready to Wheel!!!!!!!
BIGRAM's Avatar
I'm fond of MOPOWER. Do the the Dodge thang!!
1994 Dodge Ram 5.9L SWB
Old 05-24-2010, 03:00 PM   #10
KennyTJ
The Pirate
KennyTJ's Avatar
HEMI..... HEMI..... HEMI..... HEMI..... well you get the point!!!!
Old 05-24-2010, 04:38 PM   #11
Trigger
I tell you what. When I'm ready for the swap, if someone has a blue bottle and wants to hook it up to the 6 cylinder, I will put on a show.
Old 05-25-2010, 07:31 AM   #12
An old TBI 350 Chevy is dirt simple to install and cheap. Add a few mods to it and pretty easy to decent HP out of them. A guy here at work pulled a Vortec 350 long-block out of the junkyard, slapped on a Vortec to TBI manifold, hooked up a couple of wires and off he went. No fuel system mods, no computer mods, etc... I'm sure it wasn't "tuned" to run optimally but it ran well and was strong.
It was a strong engine (250 HP), at least by real world standards......and substantially stronger than a stock 4.0L. Speaking of "real world", I think most people way over-estimate what their engine actually produces, or what you need (or can actually use) on the trail.
Old 05-25-2010, 08:15 AM   #13
Hehehehe I think I can hook you up
Old 05-25-2010, 12:04 PM   #14
i would go vortec 4.3 b4 i messed with a tbi 350...very close in hp and the 4.3 weighs less and is smaller and easier to install in tight places... just my .02 i hate tbi 350 engines and i am a gm person since i was a kid...the tbi 350 was the sorriest excuse for a v8 gm ever put out...
Old 05-25-2010, 12:24 PM   #15
Personally I wouldn't bother going from a 4.0L to a 4.3.....a lot of time and effort to swap it in for really no gain. The HP is pretty close between the Vortec 4.3 and stock TBI 350, but the 350 still had around 50 ft-lbs. more torque. But the key work there is stock and the power potential of the 350 is pretty much endless and relatively low cost. The 350 TBI engines didn't have super high power numbers if compared to current day engines, but at the time they were strong and much stronger than the previous generation carb'd 350 (TBI bumped up the HP around 40-50 as compared to the previous generation), and the TBI itself is not really the limiting factor but rather the heads, cam, compression ratio, etc... in rest of the engine.
I'm definitely not saying a TBI 350 is the be-all, end-all engine swap for a Jeep, but it is cheap and easy and can put out respectable power. Service diagnostic and repair is also pretty easy as compared to modern engines.
Old 05-25-2010, 04:09 PM   #16
Trigger
Well, just looking around quickly on www.car-parts.com, I can pick up a 6.0L for the same price as a 5.3, so it looks like it might be a better route. I looked on AA, but can't find an adapter for the Gen III to TH400, but I'm sure they make one, then after that it's an Atlas. TomH, what did the swap end up running you, if you don't mind me asking. I'm thinking $6-$7K?
Old 05-25-2010, 05:02 PM   #17
TomH
Gearhead
TomH's Avatar
You're about right on. I picked up an '06 Escalade (LQ9) including the 4L65e and all of the accessories, ECM, harness etc. for $4K to my doorstep. The motor/trans was pricey, but it was virtually new (500 mi).
Between the cam, Atlas-II with adapters, VSS kit, headers, etc. there is another $3K (Max).
Old 05-25-2010, 06:50 PM   #18
if it were me... I would go sbc 350 or 400 pane injected t400 and atlas, could do that for 3500.00 4000.00 with all good parts on it. but thats me.
Old 05-25-2010, 09:21 PM   #19
I liked the jeep and how well it performed with mostly all jeep components except for the axles and suspension. Factory steering box, pump, motor, trans, t-case, body etc... Parts could be easily found at an auto parts store and a factory chiltons manual covered it. Not many rigs around that I have seen or heard of that could cover terrain as much as it could with mostly stock internals. Suspension setup was spot on and gearing was right.
Old 05-25-2010, 11:10 PM   #20
8UP
Check Pirates classifieds for the Atlas. I looked around several months ago and there were several of them at the time. Could save you hundreds.
Old 05-25-2010, 11:36 PM   #21
I'd say SBC too... For what you mentioned your budget might be you could buy a new 350 crate motor and still have some change for go fast goodies, and you can find parts just about anywhere. Just my 2 cents.
http://www.summitracing.com/parts/MLL-BP3830CT1/
Old 05-26-2010, 08:06 AM   #22
If I had to choose I would definitely go with the 6.0L.
Isn't the reason there is no adaptor for a Gen III to a TH400 is that you don't need one? I was thinking the only thing to deal with is reprogramming the engine ECU so it is not looking for signals coming from the trans???
Old 05-26-2010, 12:19 PM   #23
f4isvt
4.3 is always a good option like said close to numbers of a 350 with less weight. My buddy runs a highly modified 4.3 vortec in his mud bog truck and they make him compete in the v8 class and generally still wins or at least places. If they let him run nitrous he always wins.
1989 ext cab yota 22re bored .20 over trd cam, trd headers, Marlin crawler front bumper w/stinger, Marlin crawler roll cage, trailgear rear bumper, trailgear rock sliders, richmond 5.29's, and lockright rear, 33 nokian mt's. 10k winch. Rear disc conversion. Chromoly rear axle shafts. Bombproof motor mounts and transfer case mount. Whole lot of rust and scratches.
f4isvt is offline   Reply With Quote
Old 05-26-2010, 03:25 PM   #24
TomH
Gearhead
TomH's Avatar
The upside to the 5.7/6.0 Gen-III/IV GM motors over the 4.3 is bags of cheap reliable torque and HP without any exotic (i.e. Expensive) parts. The 5.3 is also a great option, but it comes down to what you can find for a donor.
The drive-by-wire versions run without hesitation in hot/cold, wet/dry, from the moment you turn the key and have lots of grunt from about 800 RPM up. A lot of guys go through the effort of changing them to cable throttles, but as easy as the ETC setup is to install, I wouldn't bother.
Good luck.
Old 05-26-2010, 07:41 PM   #25
Go GenIII/IV 6.0 .. I bought a low miles LQ9 locally ..complete minus the harness for $900.. 345hp stock.
Add a cam and tune and your at 400 ponies for under $2k... thats hard to beat.
Jeff
