www.buckeyejeepers.com
"THE HEEP" Buildup (SOA, 3/4 axles, Stak, Hi-steer)
Heep of money + Heep of time + Heep of parts = Heep of fun
Build consists of the following: - Front Axle -Swap out D30 aussie locked for a HP D44 with OX locker - Clean up, install High steer, install 1350 Yoke, , new ball joints, Chromoly shafts w/superjoints. - Rear Axle - Swap out Ford 8.8 open for a D60 with Detroit - Cleaned up and convert to disc brakes, Install 1350 Yoke - Tires and Rims - H1 rims and set of 37-38 inch tires, looking for TSL SX, Boggers, or IROKs -Transfer Case - Swap out the NP231 for Stak4x4 4.3:1 case - Suspension - Swap out the 3.5 lift springs for a SOA setup, for a Stock YJ & Superlift replacement hybrid pack. - Modify tub and fenders to to accept TJ flares to add more clearance for larger tires Picture as purchased in early 2006 Picture after first build, Spring 2006 Picture as of 12/11/07 progress (trying to figure out what tire size to go with) Buildup Suggestions Thread - http://www.cincyoffroad.com/forum/showthread.php?t=1027
1994 YJ, 4.0, 5 speed. *2006 Dodge 2500 Cummins, 4x4 Auto,Quad cab, LongBed, Tekonsha Prodigy(Tow Rig) Last edited by JeepHD; 01-04-2008 at 09:48 AM. |
