Old 11-17-2008, 10:11 PM   #1
jeep93zj
jeep93zj's Avatar
weld on bead locks
has anybody ever done this and how hard is it and do u put them on the front and back of the rim
89 xj 5" rustys
93 zj 7" rockcrawler springs with rustys long arms
jeep93zj is offline   Reply With Quote
Old 11-17-2008, 10:54 PM   #2
very easy , most of the kits come with an inner ring and outer ring. inner ring sits inside lip of rim. just grind off paint or powder coat and center inner ring on the outer rim ( inside of lip ) and weld it all the way around. I put a bead of RTV around my weld just for a little extra defense against leaks.
Old 11-17-2008, 11:04 PM   #3
jeep93zj
jeep93zj's Avatar
do thease just go on the front of the rim
89 xj 5" rustys
Old 11-17-2008, 11:16 PM   #4
front/outside of rim,......yes
Old 11-17-2008, 11:23 PM   #5
jeep93zj
jeep93zj's Avatar
k thanks i might try them
89 xj 5" rustys
Old 11-18-2008, 06:35 AM   #6
They are simple to do but hard to get balanced for highway driving.
Old 11-18-2008, 06:45 AM   #7
you can do them on the inside as well if you like. not common, but done sometimes.
Old 11-18-2008, 08:17 AM   #8
The biggest issue with putting them on the inside of the rim would be clearance with the brakes, tie rods, etc... This varies based on the rig, axles, and rim size, but something you need to definitely check before hand.
Generally beadlocks only go on the outside of the rim. Why? Because most of the forces that cause the bead to unseat act on the outside bead of the tire, not the inside. Plus on a standard rim, in which the drop center is at outer side (meaning you mount the tires from the front of the rims) it's a lot harder to knock the bead off. Reverse center wheels (typically wheels with 2-2.5" back spacing, aka stick out further) have the drop center at the back of the wheel meaning you mount the tires from the back. I consider these poor man's beadlocks. Both myself and 78Buford run 15x8 reverse backspace wheels and have yet to throw a bead. He runs 42x15's and I run 39.5x15's, and we both run 10 or less psi all the time (he goes down to 4-5 regularly) and these are both heavy fullsize trucks.
In my years of wheeling I've seen one inner bead lost when the outer stayed put, but dozens of outer beads lost where the inner stayed put.
Old 11-18-2008, 01:16 PM   #9
jeep93zj
jeep93zj's Avatar
ok where can i get a good set of thease for a 15in rim
89 xj 5" rustys
Old 11-18-2008, 01:34 PM   #10
i will have some more
within the next 2 weeks
when you need them?
Old 11-18-2008, 01:50 PM   #11
jeep93zj
jeep93zj's Avatar
when ever not in any hurry how much for 4 of them
89 xj 5" rustys
Old 11-18-2008, 02:58 PM   #12
For hard core wheeling make sure you get thick rings made from good quality steel.
Old 11-18-2008, 04:55 PM   #13
.....here ya go....
http://www.cincyoffroad.com/forum/showthread.php?t=1839
Old 11-18-2008, 09:40 PM   #14
jeep93zj
jeep93zj's Avatar
would u have a pic of them
89 xj 5" rustys
Old 11-18-2008, 11:33 PM   #15
well I've been looking for a while now
have pic's of a muddy set
will keep looking
Old 11-18-2008, 11:40 PM   #16
jeep93zj
jeep93zj's Avatar
thats fine how thick of steel are they made of
89 xj 5" rustys
Old 11-19-2008, 12:02 AM   #17
they are 1/4 inch thick
couple more pics
Old 11-19-2008, 12:04 AM   #18
still looking
Old 11-19-2008, 12:22 PM   #19
JasonCJ7
Throttle Jockey
JasonCJ7's Avatar
Beadlocks
Hey Fab,
Would you beintersted in swapping a set of these for Detroit in need of clutches? Or maybe some other parts...
Need a set badly before I put my new rims on. 15"
Old 11-20-2008, 10:22 PM   #20
detroit fits a what
Old 11-21-2008, 09:48 AM   #21
rob u ever come up with more disk brake brackets??...thinkin bout doin mine
Old 11-21-2008, 11:52 AM   #22
JasonCJ7
Throttle Jockey
JasonCJ7's Avatar
The detroit is for a DANA 44 3.92 and numerically higher...
