No oil to the head
I have a I-6 that is not getting oil to the head but it shows good oil pressure. I don't want to remove the engine. How can I clean out the engine? I was thinking kerosene. Any ideas?
Sent from my Nexus S using Tapatalk
Are we talking about a Jeep motor???? I would pull the valve cover and make sure the push rods are not gunked up. Are the hydraulic lifters noisy??????
#3 | |
Sorry yota but its on one of the new projects. Its a 91. It is fairly gummed up on top. I want to do what I can before the engine has to come out and gone through.
There are all kind of engine cleaners on the market, I hear good things about the Sea Foam.
I have too. But what do I do? The valve cover is off. I was thinking pour something in there and let it soak and see what happens
I would spray it with brake cleaner, change the oil, add a cleaner, follow the directions of the cleaner and change the oil again.
My 4 cylinder in my Camry has a history of sludge that I read somewhere. I will run a diesel oil in it once in awhile to clean it out. |
Sounds good I will give it a try.
