- Moderator - |
Rock rings
Got my rock rings today from Trailworthy FAB!
Saweet! Hopefully no more broken valve stems again! ![]() Sent from my iPhone using Tapatalk
Keep them on all 4's |
Nice!
Just looking at pics... So these are for your fronts (hummer wheels with internal beadlocks?), and the rears are conventional?
So it's going over the beadlock ring? Sorry, I guess I don't understand...
Ah, I see now, that's the part I was missing. Thanks!
- Moderator - |
Working on the jeep tonight. Got the tranny pulled and the upper control Y arm removed. The 9/16 bolt was seized to the johnie joint and I had to torch it out. Solid 1 1/2 thick with the ball joint and the bolt. Going to replace it with a 1 1/2 heim. New clutch installed with new hydro setup. Rock rings are going to look sick.
![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk
