Old 01-07-2008, 09:05 AM   #1
Exclamation Rockwell axle length
On the 2.5 ton rockwell axles I have a few questions. How do you make the rear and front axles the same width from wheel bolting flange to wheel bolting flange. Another is are they all 6.72 ratios? And I guess you can not rotate the pinion and count the revolutions of the wheel to get a gear ratio due to the top loader gearing. :confused:
Old 01-07-2008, 09:44 AM   #2
They are all 6.72:1 and yes, you can still do the rotation trick even with them being top loaders.
To make the front match the rear, you flip the hubs of the front axle in so that they are on the way the rears are. The bearings are the same, aside from the width of them. it will all interchange just fine.
Old 01-07-2008, 11:12 AM   #3
Thanks man! Just tore into em last night and I started getting second thoughts about using em due to some difficulties.
Old 01-07-2008, 11:17 AM   #4
There are some obstacles to overcome regarding them... They are definitely not as easy as throwing some 1-tons under there.
Old 01-07-2008, 01:30 PM   #5
I agree! I am finding them out as I go it seems. May order rims from US 6x6
Old 01-08-2008, 11:36 PM   #6
http://www.ouversonengineering.com/home
this site may be your friend
Old 01-09-2008, 06:38 AM   #7
I personnally haven't dealt with them, but their reputation
leaves a lot to be desired
http://www.pirate4x4.com/forum/showt...ghlight=usa6x6
