Old 10-30-2008, 12:18 AM   #1
302 Bellhousing and Misc Tech...
Yep, I'm worse than a girl choosing her clothes...
5.0 that I shouldn't pass up... but it's in front of an auto trans, and I dislike autos... so trying to figure out what I need to bolt it to my Ford NP435... to see if it's really worth it...
Here's what I think I'll need: tell me if I'm missing something
New Engine Mounts (this will suck given the girth of the previous version 3.0 AMC mounts)
Flywheel (157 tooth??)
Bellhousing
Clutch fork (unless AMC will work)
Clutch fork boot
External slave cyl
throwout bearing
And, I'm hoping that the DualFriction Centerforce clutch that I bought for the AMC will somehow work (at least I know that the spline count and hole diam. and outer diam. are the same...)
Anyone have any of this laying around?
Tony?
Old 10-30-2008, 03:31 PM   #2
Need to know year. Older is externally balanced newer is internally balanced
Old 10-30-2008, 05:01 PM   #3
I think it's an EFI 5.0 from 1989? LTD
edit: I'm gonna guess speed density and not MAF
Not sure if that's "Older" or "Newer"
Thanks Tony.
Old 10-30-2008, 05:19 PM   #4
PS - I'd love to see a pic of your engine mounts Tony...
Old 10-30-2008, 06:15 PM   #5
OH NOES!! my motor mounts!!!!
Old 10-30-2008, 07:08 PM   #6
trust me, I'm not looking forward to grinding those *****es off...
Old 10-30-2008, 07:51 PM   #7
I would love to show you some pics but my Jeep is an unofficial permanent landscape item at Terry's so I will see if he can email me some. They are simple. A bracket on the engine and a bracket on the frame with a bolt through them and a YJ spring bushing for the rubber.
Buy a new flywheel. $90 at KOI. 92 F-250 with a 302. This application gives you the larger clutch. I do have an externally balanced one in my garage. You can have it if you need it.
Old 10-31-2008, 12:17 AM   #8
I knew I shoulda called Terry first...
Already ordered the flywheel (I'm an impatient bastard that knows that I'll have to have the fricken thing refinished anyway)... Would that be a clutch larger than 11"?
Much appreciated Tony, and thanks again for actually adding valuable information here... guess I should really move this to tech huh?
