Old 04-07-2010, 05:26 PM   #1
nickhuts
GRAB A SNATCH BLOCK!!
nickhuts's Avatar
T18 into a CJ7
I am thinking about doing the t18 trans swap in my 1980 Cj7. I am wondering if the trans bolts right in, is there any changes in my driveshaft leanghts, ect.. anyone ever done this swap? Right now I have a T150 transmission on a 304 V8. Thanks
Old 04-07-2010, 07:13 PM   #2
direct bolt in. I did this swap on a jeep i owned previously. retained the dana20 tcase as well.
at least i recall it being a direct swap, it was like 10 years ago..
Old 04-07-2010, 07:53 PM   #3
jlynch
There are many different kinds of T18's if you are lucky enough to find one out of a cj and it has the adapter to bolt it to the model 20 transfer case it will bolt right in, however your driveshaft lengths will change. You can get a T18 out of a jeep truck as well but it will need a short input shaft put on it. Ford T18's will also work with some modifications.
This guy knows all there is to know about T18's
http://www.partsmike.com/tech-help/id-t18/
Old 04-08-2010, 02:26 PM   #4
Ok, this makes more sense... (I saw the other post first)...
The T-18 that you want is from 78-79 CJ ONLY... (6.32 first gear, aka wide ratio)
I was thinking that the 80 CJ was the oddball year -- a short output Dana300??
Are you saying that you have a Dana20 currently in the '80 CJ?
'80 was also the year that IH made a Dana300 that had the Dana20 bolt pattern... good luck finding one of those... I know of 1... and it's not for sale.
Old 04-08-2010, 02:29 PM   #5
btw, here's your T-150 next to an NP435 (also very similar size to T-18):
Old 04-08-2010, 02:36 PM   #6
And finally....
(now that I've wet your appetite...)
I have the T-18 in question... but I wasn't really planning on splitting with it... a few Dana20's as well... When you know for sure what tcase you have and which one you want to run after conversion, let us know...
Give me a call at some point, I'll PM my number...
