04-26-2010, 09:25 PM | #1 |
not starting
I need your help guys. Went out to start my samurai today and she aint starting! Battery tested good. I dont know what else to do?? Any ideas! PLEASE HELP!!My truck broke today to! I'm in school and work.:confused: :confused:
04-26-2010, 09:39 PM | #2 |
Danny Beach
is it turning over trying to start ? did you check for spark at the plugs? it it getting fuel? More Info?
86 Ford Bronco |
04-26-2010, 09:47 PM | #3 |
its not doing anything at all.no clicking or anything lights dont come on
04-26-2010, 09:51 PM | #4 |
Danny Beach
did you check fuse's under the hood?
I had a car do that it was a fuse dose the radio or anything inside the car work? thats what hapend to me wouldn't even try to start no lights but the radio and door locks worked
86 Ford Bronco |
04-26-2010, 09:52 PM | #5 |
hmm.did not look but.i will tomorow
04-26-2010, 09:54 PM | #6 |
Danny Beach
good luck
86 Ford Bronco |
04-26-2010, 10:03 PM | #7 |
still could be any number of things. Ignition switch. Starter relay. Seized starter selenoid. Loose contacts or shorted/broken wire. Do you have a good repair manual for it?
Are you getting 12 volts at the selenoid? If not the problem is before it. Bypass everything and run a power wire straight from the battery + to the 12V + on the starter selenoid. Just give it a slight touch to a good clean contact. If it cranks it's something between the key and the selenoid. If nothing still try tapping on the selenoid and repeat step 1. If it cranks you'll need a new starter soon.Start there first. |
04-26-2010, 10:17 PM | #8 |
haha.ok.sorry this is just amuzing because i just with through this sh!t with my truck tonight.its haveing the same problems.i will tommorow thanks
04-26-2010, 10:30 PM | #9 |
do you have any pictures of where the fuseable link is?
