Old 12-13-2011, 03:21 PM   #1
Ideas on my rear bumper
I'm building a new rear bumper, similar to the one I have. My problem is the square stock I'm using is three inches and the clevis mounts are three inches. Mounting them through the bumper won't work unless I trim them a lot. I also want to use the bumper for an air tank also.
So I was thinking of welding the clevis mounts, and the receiver hitch to the bottom of the bumper. That would keep the bumper open for an air tank. Any other ideas????? I"m also going to trim the points off of the ends of the bumper too.
I also made so new shock mounts for the rear.
Old 12-13-2011, 03:55 PM   #2
T-bird
T-bird's Avatar
Instead of installing the clevis mounts vertically like evryone does, you could mount them horizontally plane in the center of the tube similar to how you have it laid out in the picture. Then you could weld it on both sides and keep it air tight for your air tank. I have seen a few guys mount them this way but never for that reason.
Old 12-13-2011, 06:27 PM   #3
superjeep
Notch them down to one inch square and drill a one inch through hole and weld them front and back sides. They will resemble a mushroom stem w/head.
Old 12-14-2011, 09:21 AM   #4
I like that better than mounting them on the bottom. Who has weld on air fitting bungs????
Old 12-14-2011, 02:23 PM   #5
Most of the clevis mounts are toward the center of the bumper, my feelings are they should be by the bumper mounts the bumper is 3/16th 3x3. What atre your thoughts???
Old 12-14-2011, 06:39 PM   #6
superjeep
I alighn mine with the frame so it is pulling were it is mounted.
shawn
Old 12-15-2011, 02:37 PM   #7
Things are coming along nicely.
http://www.terrainstompers.com/forum...?p=34334#34334
Waiting for the bungs to get here then find some heavy wall tube for the swing out.
I was thinking about welding receiver hitch stock in corner to use as jack stands.
