Old 06-12-2012, 10:01 PM   #1
oops!
what's best way to go from here?
Sent from my LS670 using Tapatalk 2
Old 06-13-2012, 12:22 AM   #2
drill... heat and a easy out maybe ? lots of PB blaster ...
good luck with that....
Old 06-13-2012, 05:21 AM   #3
it got crossthreaded in...with a impact....and I was unthreading it by hand when it snapped off. most of threads are still deep in knuckle
Old 06-13-2012, 12:03 PM   #4
cross threaded too ?
I don't know what to suggest then...:(
Old 06-13-2012, 12:11 PM   #5
If it is cross threaded, drill it out and tap it to a larger thread size.
Old 06-13-2012, 12:37 PM
This message has been deleted by gothodgie. Reason: duh...
Old 06-13-2012, 12:40 PM   #7
smarty pants ...
Old 06-13-2012, 01:11 PM   #8
smarty pants ...
Looks like there is still enough bolt sticking out to weld a nut to. Take that washer off and find a nut that just fits over the existing bolt. Weld the inside of the nut to the bolt. Once it cools, you should be able to remove it with an impact.
Old 06-14-2012, 07:09 AM   #9
lol...its gettin ugly:)..
nah but todays the day. I knew it wouldent thread out, got it flush and pilot hole thru it...gottta pick up some decent bits to finish it up tonight. looks like ill take jefk5's latter idea of putting cap back on as a template.
Old 06-14-2012, 05:29 PM   #10
dougg01
Murphy wins again. As usual...there is a smooth path when things go wrong and a windy, bumpy, dirt trail and it just started raining buckets along with golfball-size hail on the direction our fixes lead to.... Someone kick that murphy guy in the jewels....
dougg01 is offline   Reply With Quote
