Old 11-21-2018, 09:48 PM   #101
Picked up a 205 today for $150.
Old 11-21-2018, 09:49 PM   #102
Nice!
Old 11-24-2018, 12:37 PM   #103
After 4 hrs of cleaning...
Old 11-24-2018, 02:34 PM   #104
All 3 shifters hooked up.
Old 11-25-2018, 03:12 AM   #105
Holy chit, is that the same box?!?
Old 11-25-2018, 11:13 AM   #106
Wow! Very nice!
Old 11-25-2018, 02:14 PM   #107
Yes sir, after lots of cleaning and wire brushing.
Old 11-25-2018, 08:02 PM   #108
Finished up the patch panels. Bodywork is too much like work..
Old 11-25-2018, 11:10 PM   #109
Like the paint job! Lookin' good Kevin!
Old 11-26-2018, 03:02 AM   #110
Very nice body work! You have way more patience than me!
Old 12-08-2018, 07:42 PM   #111
Been plugging away on the body work. Decided to do a different body color. Something a little different. Should go good with the cage color. Hoping to paint the body the week of christmas.
Old 12-10-2018, 04:42 PM   #112
What color is the body going to be? What color is that roll cage? I really like it!
Old 12-13-2018, 06:00 PM   #113
The body color is a surprise. The cage color is aluminum. I bought the paint today so there's no going back now. It cost $375 for the sealer and the single stage urethane paint.
Old 12-14-2018, 01:01 AM   #114
Iss secssy...
Old 12-27-2018, 11:46 AM   #115
Today is paint day. Have to spray 1 coat of epoxy primer and 2-3 coats of single stage urethane top coat. Gonna be a busy day...
Old 12-27-2018, 11:59 AM   #116
Can't wait to see what color you chose!
Old 12-27-2018, 04:29 PM   #117
Primer is done.Click image for larger version
Old 12-27-2018, 06:50 PM   #118
My make shift paint booth worked out pretty good. Cranked the heat to 82 after i was done. Once i get the body back on the frame, I'll post a pic. Click image for larger version
Old 12-30-2018, 12:56 AM   #119
I got the body back on the frame. I still have to weld the exo on. Brought the old rig in to tear it down and remove the drivetrain.
ID:	10230Click image for larger version
ID:	10231Click image for larger version
Old 12-30-2018, 06:49 PM   #120
Oh, that color looks GREAT. Nice choice!
Old 12-30-2018, 11:40 PM   #121
Thanks. It's dark cherry metallic. Same color as my 96 Impala SS.
Finished robbing all the usable parts off the old pig. Time to put it all back together.
ID:	10233Click image for larger version
ID:	10234Click image for larger version
ID:	10235Click image for larger version
Old 12-31-2018, 12:05 AM   #122
Love the color on the cab! Great choice with the roll cage!
Old 12-31-2018, 12:05 PM   #123
I'm only posting this info for anybody that's swapping a 241 for a 205 241 Doubler. The 241 has a long snout that basically takes up the space of the 241 Doubler. Both cases end up being 19 1/2". The big difference is it moves your transfer case farther back making your front drive shaft longer but not really affecting how long your rear drive shaft is. In my case that will make my front drive shaft angle much better than it was before. The doubler I'm using is a Northwest Fab 241 eco box.
ID:	10237Click image for larger version
Old 01-10-2019, 01:39 PM   #124
I need to make new driveshafts, so I need yokes and tubing. What is the OD and wall thickness of what you're using? I need to know what's holding up to the abuse we put them through. The last ones I built I used the 2 1/8 DOM I had laying around. I want to use something more common this time.
I also need to know how much slip to use on a linked suspension. I know it won't move as much as it did with the leaf springs. Knowing the diameter of the spline would help too.
Old 01-10-2019, 03:09 PM   #125
I may do the same on mine.. Save some money!
