Old 02-06-2010, 01:12 AM   #26
RuffedUpXJ
RuffedUpXJ's Avatar
Back to topic, why are you buying s diesel? Do you just think that you will need it in the future?
Just curious.
Old 02-06-2010, 01:43 AM   #27
BIGRAM
Ready to Wheel!!!!!!!
BIGRAM's Avatar
It's actually my brother looking, I thought I could get some good info from this site. He currently has one of the squeakiest '03 Chevy trucks I have ever heard. 4WD makes aweful noise, sounds like a cat fighting a squirrel in the rearend during takeoff and it seams like a decent deal. He will be towing his XJ to the trails so the deisel makes good sense for the power. We'll see how it turns out in the morning
1994 Dodge Ram 5.9L SWB
Old 02-06-2010, 07:58 AM   #28
truk
truk's Avatar
dont let thee auto scare you !! i towed for years with one and loved it . never had a problem with it just use your head with it ! if it starts to hunt for gears aka dropping out of OD while towing then turn OD off that should save the tranny. as far as dodge trannys being bad that may be true but all the big 3 have problems with something ford injectors on 7.3s and the 6.0s wont say anything about them except boat anchors, gm allison trannys my son in law is making a killing replace them from being used in the mines. the cummins dodge seems to be the best set-up i think . loved my 04 dodge. my 2 cent matt
Old 02-06-2010, 10:54 AM   #29
Trigger
What is he wanting to do with the truck? If he wants to keep it fairly stock, the Ford is a great choice. Yes, the 6.0 has some issues with studs and head gaskets, but only if you try to get more power out of them. I have an 06 F250 and love it. It's comfortable to drive, very quiet going down the road and doesn't feel like a truck. Plus, I tow my YJ on an 18' deckover with no problem at all. If he's going to want to add more power and be one of those Dodge guys (you know who I'm talking about), then tell him to get a Dodge. They seem to be very mod friendly and Cummins is darn near bulletproof. The downside is that the fit and finish on the Dodge isn't all that great. You basically have a great engine in a so-so truck. I don't know much about the Duramax, but I've heard they can be pretty expensive to build up and I know they are pretty expensive to get into, especially if you get a GMC.
Old 02-06-2010, 11:14 AM   #30
hotrod
Diesel guy
hotrod's Avatar
the 04 has the 48re, better than the 47re that was in the 2nd gen trucks (even tho the truck your looking at is a first gen)
and the 6.0s are bad ass if they are built and are damn decent even stock. i drive a 7.3 and has more power than you would believe. its turned up some and can pull just about anything you want.
2013 RZR S
Old 02-06-2010, 12:57 PM   #31
KennyTJ
The Pirate
KennyTJ's Avatar
I just looked through the online specs and my printed specs for CAT equipment and can't find a single mention of a Cummins motor. They had CAT C3.3, C3.4, 3054C, 3056E, 3512, 3516, ACCERT C9, C11, C13, C15, C18, C27, C32, C175. I just cant find a single reference to a cummins motor in a CAT. The little excavators have Mitsubishis in them though. If you can point me to a model that does have a Cummins, please show me.http://www.cat.com/engines
I'll keep this short not to get too far off topic but since the late 70's CAT has purchased thier engine long blocks (not all but for some of thier divisions) and had the heads and other components made from other sub contract vendors (just the same as every other manufacturer auto or other) Cummins has supplied "long blocks" to CAT from thier construction and mining engine divisions for a long time, of course contracts change all the time so you never know.
You don't see a Chevy Diesel truck with a huge flamming Isuzu emblems on it but guess where Duramax comes from.... and I'm not flaming them at all.
Never mind much like my wife this is a neverending story.... let's just move back too on topic for the OP.
Old 02-06-2010, 05:45 PM   #32
BIGRAM
BIGRAM's Avatar
Just a stock driver and the occasional tow rig. Just got back from looking and it was a nice truck. As far as the ride, it is a regular cab truck. I'm 6'2" and it wasn't as bad as I thought it may be. The odometer had stopped on 178,xxx miles, not sure how many more was on it. The tranny has been replaced and some of the front end components. Body is solid and has been kept clean inside and out, and under the hood. There negotiating, what's the value of a truck in these conditions?
Old 02-06-2010, 07:43 PM   #33
hotrod
Diesel guy
hotrod's Avatar
3-4k maybe :confused:
2013 RZR S
Old 02-07-2010, 09:16 AM   #34
RD TRCTR
Quite honestly, the truck you're looking at is a cruiser and a tow rig. The most mods that I would do to it is straight pipe it, air filter kit, boost, pyro and trans temp gauges. It'll run forever at stock power levels.
The automatic in the first gens aren't that bad, as long as you leave it alone. It's been awhile since I've been around one, but if it's possible, turn the OD off when towing and pulling grades.
The values of 1st gen Cummins trucks are all over the place. It really depends where the truck is located. All diesels sell for more than KBB value in KY, IN and OH.
If the truck you're looking at is 2WD, and in good shape, anywhere from $3k to $5k. If it's a 4WD it could be sold for as much as $10k.
