Old 03-24-2008, 11:58 AM   #1
Make sure you mount the stak itself to some sort of bracing or it will twist off the 6 mounting studs! Front track bar is rarely needed with a good leaf sprung setup.
Old 03-24-2008, 12:47 PM   #2
JeepHD
www.buckeyejeepers.com
JeepHD's Avatar
Yep, I am going to run two 2 x 2 square stock from one side of the frame to the other using poly bushings. One will hold tranny and front traction bar mount and the rear will hold stak and rear tractions bar. I will also tie the front and rear 2x2s together.
Friends watched and said my front was wrapping pretty bad also. I am running stock YJs with an added main leaf. I have 7 inch perches on front and rear. I would rather run traction bars and keep the soft springs that run stiffer springs. I would be open to other spring combinations, but I want to keep it as low and flexy as possible.
Thanks
1994 YJ, 4.0, 5 speed.
