Old 05-09-2008, 08:31 AM   #8
Know someone (Applegate )who removed both front and rear swaybars from their Tj. I guess thats why it would always lift the right front on turns and under hard acceleration.
Let me guess, short arm lift kit? If so that is a common trait when using the factory control arm mounting points when lifting it. Not really the swaybars fault but does seem worse with the front disconnected simply because the swaybar masks part of the problem by limiting wheel travel.
