Old 05-08-2008, 06:54 PM   #1
Know someone (Applegate )who removed both front and rear swaybars from their Tj. I guess thats why it would always lift the right front on turns and under hard acceleration.
Old 05-08-2008, 09:03 PM   #2
yes, applegates tj was squirley. removing the rear is fine, almost cant tell. get rid of that front, and it becomes an adventure on the street.
Old 05-09-2008, 08:31 AM   #3
Let me guess, short arm lift kit? If so that is a common trait when using the factory control arm mounting points when lifting it. Not really the swaybars fault but does seem worse with the front disconnected simply because the swaybar masks part of the problem by limiting wheel travel.
Old 05-09-2008, 08:54 AM   #4
he had no lift kit. might have even had coils spring spacers, making his arms even that much shorter.... ha! well didn't make the arms shorter, but shorter in reference to the height of the rig over stock.
