This this has turned out great!!
Very cool build, I hope to see it out on the trail sometime. |
#3 | |
www.buckeyejeepers.com
Thanks, Now I just need to get it to sit lower! 1 inch body lift is coming off and I am going to try to raise the rear spring mounts about an inch to loose another 1/2. Hopefully the springs settle down about an inch or so also.
Did it hop the same way before the traction bar? Just wondering if the geometry (anti-squat) of the bar is part of the issue. A guy in our club put a traction bar on his and afterwards it would almost jump completely off the ground because of the super high anti-squat.
Make the rear bar as long as you can. I had a similar issue with the traction bar in my old XJ. Would hop around after breaking loose. I lengthened the bar and it got better but would still hop a little. I completly solved the hopping in my new truck with a 4 link.
Good Luck, AARON
91 MJ Under construction |
jeephd
hey i came accross these springs. have you checked these out for your soa? i've always heard rubicon has the best leaf springs.
http://www.quadratec.com/products/16311_5111.htm |
#7 | |
Thanks Josh
