Old 01-08-2010, 08:53 AM   #1
TSL bias ply up front and boggers on the rear for my vote.
Old 01-08-2010, 09:04 AM   #2
mossyoaktj
mossyoaktj's Avatar
id probably go as low as a 37. but i can never find a set of 15 its always 16's. i should be home in march for about a month so its goin to be my dd then. but it isnt goin to go far from home or get over 50mph. ive been lookin for tires for awhile now for this thing but all i can find are sets of 33's and super worn 35's. a few 42's and even a set of 39 boggers. but the truck has 39s now which rud slightly when turned all the way to the right. so im droppin the size just a bit. the tires it has now are belted mickey thompson. which are worn in the middle and it like to run the road whenever it wants.
UNITED STATES MARINE
Old 01-08-2010, 03:49 PM   #3
Waffle's Avatar
Images: 10
I'd pick sx's.....they will at least be great in all aspects of wheeling. Boggers, only 1 and thats mud. Plus you mentioned tire rub, well the boggs have some nasty lugs at the tires edge. Pick your sizes wisely........02*
Old 01-08-2010, 04:48 PM   #4
Originally Posted by mossyoaktj View Post
but the truck has 39s now which rud slightly when turned all the way to the right. so im droppin the size just a bit. .
about 30 minutes with a cut off wheel on a grinder and sawzall would cure this problem. I run 39.5" Swampers on my Chevy with only a 4" lift, if I added a 3" body lift 44" tires would be no problem.
Old 01-08-2010, 04:50 PM   #5
Jeffd
Thumbs up
I would run sx`s in the front and boggers in the rear that way tou can still steer and the boggers will still push
Later Jeff
Jeffd is offline   Reply With Quote
Old 01-08-2010, 05:53 PM   #6
I've run both and love both.
The SX is undoubtedly the tougher of the two tires ... I've seen Boggers cut sidewalls. SX's also work good in all but the thickest mud.
Boggers on the other hand do lack a little side hill capability but it's not impossible to deal width , after running them for awhile you'll find you've altered your driving style and no longer notice it. They also suck up HP and don't do all that great if you can't spin them in hard the mud.
I think Boggers climb steep rocky hills better and look sweet
Boggers are also hard on drivetrain parts.
Old 01-08-2010, 10:05 PM   #7
mossyoaktj
mossyoaktj's Avatar
well hopefully he get the title tomorro bu im probably goin to get the sx's. thanks for all the advice
Old 01-08-2010, 10:07 PM   #8
boomhauer
boomhauer's Avatar
i agree
Old 01-08-2010, 10:16 PM   #9
i agree
i'll x3 this. gives you some lateral stability in the front for steering, and gives you the dig of a bogger in the rear. you could always groove the sx's to give you a little more bite in the front too.
greg
Old 01-09-2010, 09:48 AM   #10
Waffle's Avatar
Images: 10
you could groove the boggers as well. Maybe every other lug just to help out a bit.
Old 01-09-2010, 10:12 AM   #11
X4 on this.... A good combo
Go Bengals!!WHO-DEY!!!
Old 01-09-2010, 03:13 PM   #12
mossyoaktj
mossyoaktj's Avatar
WHO-DEY is for sure.. but i think the tires may have to hold off for a few. i came across a 94 yj with SOA and a decent set of 33's. so thats the goal right now.PLAYOFFS=WHO-DEY
Old 01-10-2010, 12:19 AM   #13
mossyoaktj
mossyoaktj's Avatar
well the jeep wasnt what it was supposed to be so bck to the drawing board
Old 01-10-2010, 12:54 AM   #14
"I've seen Boggers cut sidewalls"
i have seen this also... hahhaah.
