Old 06-12-2007, 01:02 PM   #6
Their should be another relay in the fuse panel that is identical that you can use to diagnose. You can also use a volt meter and check it. I had a similar problem and ended up having to have the truggy wired from scratch and paid 2000.00 for it. :o Always disconnect the battery before welding on a vehicle.
