Old 03-16-2012, 07:32 AM   #3
Sounds like a fuel delivery issue instead of a spark issue. Change a fuel filter if it has one external. Clean the MAF sensor. That's where I would start.
yeah just found some site with that info too with other issue to check
intake gasket leak around #4
egr
injector
oil in distributor ( bad seal)
question why would fuel filter cause issue only at low idle and not higher rpm?:confused:
