well i just picked up a 94 altima gxe and it has a ruff idle. it is running around 600-700 rpm. It will spudder on take off through first gear and then smooth out in 2nd gear and beyond.. come to stop and ruff idle comes back.
I swapped out the following: wires plugs cap and button put some seam foam in the tank..to try and clean injectors.. did not put it on a timing light engine is not throwing out any codes that i know of... what else could I check? o2 sensor? I looked for vacuum leaks but did not see any... i have been searching online for this issue and some say oil in the distributor 9 did nto see anything there went i put button in) or a failing MAF ( maybe clean it?) not sure where to go next...
Thanks, 67fastback ------------- 84 Honda cr60r - for sale 87 Honda 200sx - for sale 67 Mustang fastback - under restoration MCA #63430 04 Silverado 2500 crew cab 87 sami - "SPLAT" 87 sami tin top - "Blue Fire" 88 sami - "Squirt" My New Video Channel -http://www.youtube.com/PhillbillyProduction My Video Channel - http://www.youtube.com/justworkn ![]() Last edited by 67fastback; 03-16-2012 at 05:31 AM. |
#3 | |
intake gasket leak around #4 egr injector oil in distributor ( bad seal) question why would fuel filter cause issue only at low idle and not higher rpm?:confused:
well i think i got it fixed up turned out # 2 cyclinder was not getting fuel.. injector was bad... swapped it out and running 30000 times better, hit the gas and takes up and squeels the tires now.
now to find the fuse for the clock and radio and find out why the air bag light came on..grrrrr. ![]()
