Old 01-14-2008, 02:39 PM   #1
Tubing bender would be fun to make! If you make one put hydraulics on it! No arm powered junk that will wear ya down! Good luck on the machining trade ;)
Old 01-14-2008, 03:49 PM   #2
you are welcome to come here and measure my bender as well, it is a jd2 model 4 full hydraulic.
Old 01-14-2008, 10:50 PM   #3
MrShoeBoy
It might be a while before I can build a bender. Have to start with baby steps then work up from there :)
As far as when classes are offered...Check out the website and go from there. www.onestop.uc.edu They list the class offerings there as well as everything else.
AARON
91 MJ Under construction
