tranny and tcase ?
need to know if i can swap out my 203 with a 208 tcase without changing output on tranny?
the tranny is a 350 turbo. i have another tranny that is mated to the 208,but am hoping i can just swap out the tcases and adapters?
Nick Prater Plum Nutz Creationz 17706 st rt Wellston, Oh 45692 https://www.facebook.com/PlumNutzCreations |
both of the tcases are mounted to th350's if that helps out any.
I'm going to assume that both the TH350's have a 27 spl output... as I believe that the 203 only came in a 27 spl version behind a TH350.
But I haven't a clue about the 208... crack'em both apart and count splines and check dimensions on the outputs... if they're the same, slap 'em back together the way that you want. Just my $.02
