Old 02-07-2008, 06:35 PM   #1
sounds cool. you plan on tubing it out, exocaging or just full bodied? how close to stock wheelbase are you going to be? your desired width might be hard. butch is at 90-92" with his hubs flipped in with 42's on his (unfortunately 4" narrower than my wide ass pig). his wheels are backspaced just enough for his hub to be just inside the wheel.
greg
Old 02-07-2008, 07:58 PM   #2
greg
What is his rims backspacing and width? I am looking at 16.5-10 rims with 4'' backspacing and hubs flipped. Hoping to get 90" from that.
Old 02-07-2008, 08:58 PM   #3
cheapthrills49
VANILLA GORILLA
cheapthrills49's Avatar
don't you have 2 run 20" rims when you flip your hubs, for clearance
Old 02-07-2008, 09:22 PM   #4
See.
Here
Old 02-11-2008, 02:36 PM   #5
http://www.cincyoffroad.com/forum/showthread.php?t=1511
Old 02-11-2008, 10:57 PM   #6
RuffedUpXJ
RuffedUpXJ's Avatar
You are killing me Scott just get the pics on here.
What was the old Truggy's wheelbase? with the 44's or so wouldn't you want to have a wheelbase more like 108"-110"?
Old 02-12-2008, 07:43 AM   #7
Old truggy was 118''. I do not want anything shorter than that. Climbing cliffs is what I do best. Rock crawling and mudding are 2nd on the list and at 118'' that was not a problem. If I am 130'' or so the good thing is that my driveshafts will bew tucked up under the chassis and not vulnerable and I will have a low center of gravity.
Old 02-07-2008, 09:24 PM   #8
nah, there is nothing really to clear, unless you are running wheel brakes. even then i have seen it done with 17" wheels.
my hubs will be flipped, and i am running 16.5" hummer wheels.
Old 02-07-2008, 09:25 PM   #9
stock hummer width, with centers he made. the center of the wheel is 3" front lip of the wheel. i lied, his hubs are flipped out. he backspaced them to where there was about an inch of clearance to the drive flange (width of drive flange will be the same no matter which way you flip the hub, that will be your problem with width i think. he is exactly 7'6" wide or 92" for the mathematically challenged.
where did you get your rockwells? i know of a set for sale that are basically identical to your specs, just wondering if they were the same ones or not.
greg
Old 02-07-2008, 09:38 PM   #10
Rockwells from the 50's to 90's are the same maybe even earlier and later. I bought 4 trucks within the last 2 years and have a few now.
Old 02-07-2008, 10:09 PM   #11
i forgot to mention, the reason he didn't end up flipping his in, is because of clearance issues with his airshocks. his front tubework was already done from when he had my 60's under it, and he didn't want to have to redo it all to make new upper mounts.
Old 02-08-2008, 04:53 PM   #12
JasonCJ7
Throttle Jockey
JasonCJ7's Avatar
Here ya go
Here are a couple pics to make your mouth water Scott.
Old 02-08-2008, 05:12 PM   #13
Man, that is tall...
Where's the pic's
