Here is some quality USA 6x6 work... they sure are some good welders out there.... There are their kingpin mounted boot guards. Had to go to them, couldn't get them from anyone else, and didn't have time or energy to make my own... wish i had just done it myself now, as i had to do quite a bit of welding repair on these as well. Not sure what monkey ass they have welding there, but they need to get some skoolin'.
![]() ![]() ![]() ![]() ![]() Hammered out my kingpin bushings and pressed in new ones. Now of course they won't go on. I have heard all kinds of answers to this, need to find a real source of knowledge on how tight these should be on the kingpins. Anyone? ![]()
Pulled all the spindle studs from the knuckles, as to clear the wheel studs since i am going to run hubs flipped in. Picked up the 3/8x1" bolts to replace them with.
![]() ![]() Here is a nice series of pics showing the clearance issues between these two items. I set a hub on the table, threw a bearing in the race and dropped the spindle in. The first pics are of the wheels studs, new and unmolested. then shots of them ground down, and showing the clearance. before shave... ![]() ![]() ![]() ![]()
Looking good CW, the wide doesn't seem to be too bad. It looks a whole lot better with the tires on giving some perspective on the overall looks.
Nice work!! It looks like an entire different animal with tires on it! It's going to be a beast!
Shaving the stud heads for clearance and using flat head cap screws in the knuckle side correct? I hate flat head cap screws but not many easy options to avoid using them from what I saw when I was at this stage. Looks good! When can you forsee firing it up?
