#101 |
Billet adjustable aluminum throttle pedal from Speedway Motors... should fit the bill nicely...
![]() Lance stainless ball valves from Afco. Posting these for other's reference. Spidertrax quit carrying this valve, and Afco directly was the only place i could find it. Summit listed it, but was backordered til end of march. Afco part number 40199. ![]() ![]() I decided on the plastic brake line kits from Speedway as well... Bought two kits. One might do it tho. Can't imagine plumbing my entire brake system for $26. Even at 2 kits, $50 brakes is a super deal. Comes with all kinds of extra fittings, unions, etc. Should be an easy install. ![]() ![]() And the rest of my steering parts, waiting patiently. ![]() More work this weekend: bump cans installed, interior panels started, pedals installed... depends on how much time i get over there.
#102 |
#103 |
#104 |
whatever man, it's light as a creampuff.
the only thing really heavy are the axles and wheels/tires... the rest is standard. Lets start a contest... guess the finished weight of my rig. Closest guess gets a prize, and i will make it a good one. Just to recap for those that want in on the contest... Full tube chassis - mix of 1.75 x .125 and .109 wall Aluminum panels outside and inside Stock YJ hood and grill Stock CJ cowl SBC 355 TH400 STAK 3 speed Rockwells - no rear steer Recentered H1 wheels 44" Boggers PRP seats That should be enough to make an educated guess. I will leave my guess for last cuz i don't want to sway anyone elses. By the way Brad, what you doing tomorrow and Saturday? Mike
#105 |
Weight will be 4969lbs. and 96 ozs. topped off with all fluids and you!
![]() Last edited by 94Dodge Truggy; 03-06-2008 at 10:02 AM. |
#106 |
#107 |
Is this with you in it or not?
![]() with out you in it 4625 |
#109 |
anywhere but there
i'm going to be optimistic and go low at 3900.
#111 |
$100.00 says I am the closest so far!
#115 |
Tire/wheels--800
Diffs complete---1,500 Chassis---1,500 mtr/trans/tcase/dshafts---850 everything else--450 5,100 |
#116 |
I'll go Jeff's 5,100 and up him a thousand. 6,100 pounds that is.
#118 |
5500 sounds like the winning number to me!!
#119 |
#121 |
5300 lbs sounds hopeful but I dont think you can get it that light
#123 |
5019
#124 |
without knowing how many feet of tubing was used,or the weight of the brake line kit,I'll guess 4,700
