Old 06-13-2008, 11:18 AM   #1
Sounds like the Gov. is sticking . I would try to put a bottle of Lucas in it and drive it around a little. the trans fluid should be approx. an inch or so up on the dip stick . I have had great luck with the Lucas oil products .
Old 06-13-2008, 04:49 PM   #2
Hybrid
Hybrid's Avatar
Should I put the entire bottle in the tranny even if the fluid is at level? How big of a bottle should I use or does just come in one size?
Old 06-13-2008, 05:08 PM   #3
cheech
Make sure you have the cable adjusted properly, quick way to burn a 700 up.
It is not a kick down cable, it is called the throttle valve cable and controls line pressure and line rise. One link on adjusting numbers 4 and 5 i believe http://www.transmissioncenter.net/subject.htm
cheech is offline   Reply With Quote
Old 06-16-2008, 01:49 PM   #4
Hybrid
Hybrid's Avatar
Well I figured it out! The throttle valve cable just needed a little readjustment. Once I properly reset it the tranny shifted smoother than silk! Thanks for all the info and help!
