Old 06-20-2008, 12:04 PM   #1
Have you checked for any codes? The first step I would do is check the fuel pressure, should be able to borrow rent a gauge and I'm assuming there is a test port somewhere around the intake.
Did it start doing this before or after all the parts you listed were installed?
Old 06-20-2008, 03:02 PM   #2
jeepbmxin
Guest
Posts: n/a
its not getin the right fuel pressure i had a 88 that did the same thing ethier the pump u put in there is bad or the little rubber hose that conects the pump to the cindig unit may have a crack or the clamps might not be tight and gas could be leakin out the hose
Old 06-20-2008, 06:25 PM   #3
pete
this was doing this before all the new stuff. have checked fuel pressure and it is right were the book says it should be. also have checked the little line you say with the pressure and it does not loose any pressure. it acts like it is choking out or starving. thanks for all the input willing to try anything need to get this to run.also it is not throwing any codes. jason came over last night and we still couldnt figure it out. thanks pete
pete is offline   Reply With Quote
Old 06-26-2008, 10:27 PM   #4
TPS switch possibly? Wiring problems? Sounds like a hard one to figure out!
Old 06-27-2008, 03:25 AM   #5
xj-up
Jeep XJ
xj-up's Avatar
Its sound like a fuel pump problem. How new is the current pump.
At idle there is no load on pump but, driving it normal heats it up and slowly shuts down until it cools and then truck will start. I have replaced many Chevy pumps having these same problems.
Also check to see if you have any smashed or kinked fuel lines.
Later,
Shane
01' Softail
71' Dodge Challenger
Shane
xj-up is offline   Reply With Quote
Old 06-27-2008, 05:53 PM   #6
My guesses would be:
Throttle position sensor, check the voltages closed and full open (naturally with the engine not running)
Temperature sensor, this will control to a degree leaness for fuel.
Map Sensor: drop in pressure will greatly affect the motor. More load could be loss of pressure. Possibly cracked hose you can't see.
IAC Idle Air Control. this will affect how much air fuel mixture you get. You said it acted like it chokes out...THIS COULD VERY WELL BE IT. Could be stuck in a open or closed state.All else fails after these...go to junk yard and get duplicate ECM. Computer could have taken a surge and messed up eprom.
Old 06-29-2008, 12:29 AM   #7
pete
FINALLY got it figured out. it was the spider. went to pull and pay and got one put it in and it runs great. thanks everybody for all the suggestions. thanks pete
