Old 06-27-2008, 05:53 PM   #1
My guesses would be:
Throttle position sensor, check the voltages closed and full open (naturally with the engine not running)
Temperature sensor, this will control to a degree leaness for fuel.
Map Sensor: drop in pressure will greatly affect the motor. More load could be loss of pressure. Possibly cracked hose you can't see.
IAC Idle Air Control. this will affect how much air fuel mixture you get. You said it acted like it chokes out...THIS COULD VERY WELL BE IT. Could be stuck in a open or closed state.All else fails after these...go to junk yard and get duplicate ECM. Computer could have taken a surge and messed up eprom.
Old 06-29-2008, 12:29 AM   #2
pete
FINALLY got it figured out. it was the spider. went to pull and pay and got one put it in and it runs great. thanks everybody for all the suggestions. thanks pete
pete is offline   Reply With Quote
Old 06-29-2008, 08:21 AM   #3
Old 06-30-2008, 03:03 PM   #4
what is a spider?????
Old 06-30-2008, 03:11 PM   #5
a spider is a complicated fuel injector inside of these chevy motors. not tha thard to replace but can cause all sorts of problems when it goes bad.
