Gearhead
Alignment Shop?
Any recommendation on an alignment shop that can handle D60's F&R?
My usual shop that handles the DD suggested going to Bethel Frame & Wheel Alignment. Being in Anderson, that's an easy choice, but I was sondering if anyone here had any experience with 'em. Thanks! TomH |
Gearhead
I didn't get it either. Perhaps it's related to the 37" rubber or the 4-link, but their answer was "No can do, we don't have the right adapters"
Storm Chaser
Adapters for your wheels is the only thing possible for the alignment heads. Some beadlock rims/large rims with little or no lip make it tuff for some heads to hook up correctly without adapters.
What type of rear end you have makes zero diffrence. I've never used Bethel Frame & Wheel Alignment but I'm sure they can do it. I use my shop in Lawrenceburg or Harrison Frame and Axle in Harrison,Ohio. |
#6 | |
I have know them all of my life and they are good people to deal with. |
Jeep XJ
How heavy is the vehicle. I had a problem finding someone to do my dually. They said it was to heavy for their alignment lift.
90' Jeep XJ Buggy - 5.5 custom lift, 33" TSL's, locked 01' Softail 01' Dodge Ram Cummins 3500 4X4 71' Dodge Challenger Shane ![]() |
Storm Chaser
^^^Sometimes thats true. I can lift up to about 8K on our rack's and if that dosen't work we have a pit rack that will do anything...eg semi's,Motor Homes etc.
Not all racks are the same as far as GVW goes either. |
Gearhead
Bust out a tape measure and angle finder and do it yourself. I ran into the same issue about 6 months ago when I tried to find a place to align my truck. Apparently a custom built 4 link in the rear and 3 link up front are too much for alignment shops to handle even though theres more adjustibility and its easier to do than factory origional
![]() AARON
91 MJ Under construction |
Gearhead
Mr ShoeBoy,
I used plumb bobs and a tape measure to get close, but the steering is still real "busy" and needs a lot of attention while driving. I suspect that it's either not square or I'm off on the caster/toe "balance." That being said, I'm planning on letting a shop get it on a frame table to get it right and then I can take measurements back at my place for keeping it in (returning it to) spec with the tape/angle finder. (I also agree about the adjustability of a 4-link, but I need a good starting point.) I'm also figuring that a reputable shop gives me a second set of (trained) eyes to validate my steering set-up. Thanks. |
#12 |
No problem TomH.
What tire size are you running? I have found that the bigger tire size less caster can be used. Typical caster is between 5 and 7 degrees. Toe in is anywhere from 0 or 1/16 to as much as 3/16. When I had 33s I had 6 deg caster and 1/8" toe in and it drove great. After going to 35s the same alignment specs didnt work out. I am now running 4 deg caster and 1/16 toe in and its great going down the highway. If you cant find a shop to do it, try tweaking with the caster and see what happens. Good Luck, AARON
#13 |
Gearhead
#14 |
Gearhead
