www.buckeyejeepers.com
What about a CO2 setup? I have been looking into them some. Lot simpler and have some good advantages. Only bad part would be having to get them refilled. www.powertank.com and www.ultimate-air.com.
Guess it depends on what you plan to use it for the most.
I seem to use alot of air for myself and others. Like to make plastic bottle pressure bombs while taking wheeling pit stops.
I ended up converting my Saden stock AC compressor to be an OBA compressor and so far everything is running great. I put an oiler and a filter in so that it runs correctly and I have a 5 gallon tank that supplies enough air to bead a tire and a pressure switch that regulates the pressure in the tank. I have two quick disconnect and a 25' hose to reach around with.
I do understand the point of not having the vehicle on to use it sometimes I wish I could have the Jeep off and have air. But the volume I can run beats out the CO2 system and not having to refill the tank s what sold me plus $125 total for the system is nice.
I do not want to add another air compressor under the hood. I want a seperate electric pump and 3 gal. tank. I can run it with vehicle off with the backup battery for a bit if needed.
Very true I have heard the Viair and Kilby are both very good having complete kits but you might be able to piece it together cheaper if you don't need all of the bells and whistles.
http://www.viaircorp.com/480c.html that is the higher end Viair compressor. Although this compress draws 40 amp it can really push some air http://4by4connection.com/exsev12volai.html
http://www.4x4wire.com/tech/portable_oba/
older write up on a system. Also search on ebay,,, found a few systems in the 150 price range on there |
