Put the diffs in the CJ ... I've seen a couple jeep tubs on K5 chassis and they look like ****... I can't imagine that Bronco frame would look much better.
I think the 78-79 Ford D44's had cast radius arm mounts which can be difficult to convert to leaf or coil/air but it is doable. With the diffs you will need the driver drop 205 and the C6 ... hell you might as well put a 5.0L in it will you at it. |
