I will be out there somewhere...See you all then.
Finishing it today. I decided to do some maintenance while I had it tore down, so pulled the front carrier and put in a new pinion seal, axle seals, hub seals, grease packed all bearings, changed gear oil front and rear. Checked other heims. Also added a pillow block bearing and crossmember for the rear driveshaft to get it up out of the way. Gotta build the driveshafts today.
would someone who is definately going to come down please call me...(859) 595-0305. thanx, boomhauer.
truggy you allowed to go?
boomhauer anyone get in touch with u?? u can call me if u need 2 513-509-9714 ill be down there all weekend with the rest of the group so if u need 2 get in touch with us call me...
yeah, fabricator called. thanx anyway. i may have one of you all if possible stop by brad's house and pick up a grill for me if not too much trouble and then drop some cash off to him on way back but will let someone know for sure this week about that. see all of you this weekend. if you aren't gonna beat the **** out of it stand back and watch me, casey that includes you. lol
