They will mark them, and that will save your life, but you still have to know where their utilities easement is so you don't put anything that encroaches the easement. they won't mark the easement, just the actual pipe and cable locations.
Unimog 406 XJ with a bunch of stuff put on by somebody else |
They mark it and want you to work around it when it is in my sub grade instead of moving it. The most fun I had was in Fairborn knocking off the taps on the gas line. DP&L would just stuff a rag and duck tape it. It did make grading the street easy since the sub grade was the same grade as the top of the gas main. And yes it was a low pressure gas main.
