Just afraid my junk won't fit...
![]() Anyone else have to make a garage door bigger?
I let the air out of my tires
I have to use the front and rear winches to pull me down to barely squeeze in with 1/2 of an inch to spare. The tires have left their marks on the sides of the wall also! Just buy a barn on wheels.
winches front and rear and suck it down
One of these days Zuk 2.0 |
Does it even have a header? If it has trusses for the roof making it 8' should be easy.
#7 | |
Wasn't as worried about the Jeep as other things... (Jeep will have dedicated front and rear axle adjustment) but less worried now... I just measured...
Boat is 6'10" as it sits... *should* be OK Big Red Truck (which probably won't stay in, but is needed to get the boat/Jeep-trailer from the rear of the garage) is 6'9" as it sits... NEED to keep the conversion to 4wd close to that height, and will most likely have to loose the little rack thing on top. I know the Jeep trailer is too tall with the ramps up, but I'm wondering about ability to put them up inside the garage... Quote:
Nice and close to me too. Maybe we can finally hook up.
Roger that. Still haven't even looked at that stuff. My apologies Tony.
Will you be getting a house with your garage??:p ??
Let me know if you need any help when the time arises.. Jeff |
