Old 05-10-2009, 01:56 PM   #1
maddhatter
maddhatter's Avatar
PM me your # 94YJ
15" locks are 200 w/o hardware......8 rings 32 bolt holes
16" locks would be about the same......8 rings 32 bolt holes
but would need a wheel to program and cut
the 16" rings.
could probabally deliver within the 275 loop
during the day
if you are not in a hurry..
So you only use 2 rings and no spacer center rings?
Old 05-10-2009, 07:48 PM   #2
You just need to pick up some 1/8"x 1/2" stock to bend and tack weld your own anti-coning ring in there. It is easy. Bend it around as you are tack welding it, and cut it to length when you get it wrapped all the way around and finish the deal.
Old 05-10-2009, 09:11 PM   #3
maddhatter
maddhatter's Avatar
Sounds a lot harder then just making 12 rings. LOL
I would very much like to see it done the way you said. The one thing I didn't like about my last set was that the anti-coning rings were to thin.
Old 05-10-2009, 10:51 PM   #4
I dont run them
i feel the more the ring cones the less the steel cuts into the tire
to each his own I guess
as Casey said shouldn't be too hard to make some
if thats what you want
Old 05-11-2009, 04:51 AM   #5
maddhatter
maddhatter's Avatar
I dont run them
I was really just asking. I am sure you know far more about bead locks then I. I can see how the outer edge would cut in a lot less if the outer ring had a bit of coning to it. I had never even thought about that.
Thanks.
Old 05-11-2009, 05:45 AM   #6
I always grind a nice radius along the entire outer edge to help keep the cut's minimal.
