Old 05-19-2009, 09:42 PM   #1
SixFtUnd
Danny Beach
SixFtUnd's Avatar
the drive shaft in the front will turn maybe 1/4 inch or so where the rear will not move at all
will check the voltage regulater may just go get one it's only $16.99
Thanks all
86 Ford Bronco
Old 05-20-2009, 08:09 AM   #2
#1 - probably not an issue. Did you only try this once, as in not moving the truck slightly and checking both the front and rear again? The diffs will always have a small amount of play if you try to turn the driveshafts while the truck is sitting still. The ring and pinions, if properly setup, should have a small amount of backlash between them (meaning the pinion can turn a very slight amount before meshing with the ring gear).
#2 - I would also check the wiring for loose connections or a bad ground, especially before spending any money.....a part may only be $16.99 but if you don't need it that is the same as throwing $16.99 out the window while you drive down the freeway.
Old 05-20-2009, 05:25 PM   #3
SixFtUnd
Danny Beach
SixFtUnd's Avatar
true it hass all new batter cables I need to look at the voltage reulater and check them wires
86 Ford Bronco
